Hi,
i am frank from Germany and i am a new owner of a Kip KK300 from 1989.
Unfortunately is the outer rubber profile from the door missing.
It would be great if someone could make a photo from the rubber profile .
Thank you very much,
Frank
KIP Kompakt 300 deur rubber
Re: KIP Kompakt 300 deur rubber
Sorry, I don't know the exact model you need.
But, if there isn't any solution, maybe here: https://nl.aliexpress.com/item/2Meter-D ... 4c4dEMB7zC
Hi Chris,
thanks -yes i thought about that...
I ordered different rubber samples via internet but till now without success - the shape was wrong
I asked KIP and they only have the inner frame rubber.
Frank
Frank
I think that no rubber was intendend on that place in the door. Nur im Rahmen Der Tur (inner frame) ist Rubber.
Mazda CX-30 Homura 2.0 E-Skyactiv automaat + Adria Action 361 LH
Hi atria,
i have found pictures at ebay which looks like there ARE rubber round the door...
Can you make a picture of the frame of the door?
Usually there is no rubber on the door when the rubber is on the frame.
LOPEN 2 GELIJKE DRAADJES !!
Micky heeft al toegezegd in het andere draadje foto's te maken.
Kan deze op slot.
Kan deze op slot.
