Deur rubber Kip kk 300
Hi,
i am Frank from Germany and i am a new owner of a Kip KK 300.
My problem is that my caravan has no door rubber.
Where can i buy the missing rubber profile?
Thank you very much and best regards
Frank
Frank
Re: Doer rubber Kip kk 300
You could try the factory in Hoogeveen, they have a parts department there.
http://www.kampeerparts.nl
Depending on where you live in Germany you could also drop by Caravan Centrale Leuvenheim (30 minutes from Arnhem). They have a lot of parts in stock as well.
https://www.cc-leuvenheim.nl
But overall I think that the door rubber is nothing special and that you should be able to buy this rubber in a caravan accessories shop. They will probably sell this stuff per meter.
Thanks for the usefull suggestions.
First place i contacted was the kampeerparts site. They send me a sample but it was not the right one...
I have seen a lot of rubber profiles at german internet shops and
If i had a picture it would be so much easier to find the right profile.
Nevertheless i will try your adress leuvenheim.
Frank
Frank
Re: Deur rubber Kip kk 300
guck hier mal, die genaue mass kann ich dir jetzt nicht geben, mein Kip steht hier erst wieder am Wochenende.
https://www.aliexpress.com/item/6M-Bott ... 05039.html
Hallo Micky,
kannst du mir dann ein foto machen?
Heel erg bedankt,
Frank
Heel erg bedankt,
Frank
Ja, kann ich machen
LOPEN 2 GELIJKE DRAADJES !!
Nu niet meer.
Nu niet meer.
@atria
The caravan is not at my place-i will post a picture next weekend.Can you make a picture of the frame of the door?
Usually there is no rubber on the door when the rubber is on the frame.
Hier sind meine Fotos, wenn du fragen hast, höre ich es gerne:
